Service engine with orange wrench
Jeffersom
GA
2012 fiesta
I have a 2012 Ford fiesta 1.6 L The orange ranch has come on and I stopped at a dealership to check the codes and they can’t find any clothes but I keep getting the service engine soon light anybody have any fixes for this
Well, didn't the Dealer reset the light for you?
You just may have the "Maintenance reminder light" as a XXX,XXX number of miles, you should check on and maintain YYYY sort of thing...
If not codes, and your I/M information Monitoring is showing PASS or READY then the messaging reminder light isn't supposed to put you into limp mode.
That's' the interesting part.
So, if the Dealer couldn't find anything, yet your vehicles in "limp mode" then you should have the little engine light too. IT's almost a requirement - for by then you'd have codes set.
So, you can try and see if this is a glitch or something the mileage odometer "checker" the OBD has inside it's own CPU - you may need to clear that "Wrench"
Do this...
Turn car off - leave it off for several hours - cool it down.
Get into the car - put in the key, don't turn it yet, place your feet on the Brake and Throttle at the same time - press them down firmly (to the floor) and hold - turn the key - past ACC to ON and don't start the motor - just hold the pedals to the floor for at least (For me) 10 seconds. This lets the lights on the dash wink out, and you'd only have Engine, and Oil light on and maybe the Wrench - check your "monitor" on the Dash Center Console - see if it says anything - like Performance Monitoring Reset in progress - etc - then release the pedals - and wait 30 seconds. Turn off key - wait another minute or so - then start your car and see if that wrench returns.
If not, treat it like you've just done an oil change - gingerly drive the car for about 10 minutes or so and see if the "Wrench" light returns.
This pedal reset procedure in is your owners manual under Oil Change - Reminder Reset
B
Jeffersom
GA
2012 fiesta
It’s a yellow wrench and the center console comes up Engine malfunction
And no DTC codes... Hmm...
Is yours a MANUAL transmission or Auto?
Had a "Wrench light" come on when I first got my car as new - took it in they said it was related to a "A-B" starter interlock switch and takeoff feature.
Apparently one of the "plunger switches" that work in both the Brake light pedal switch assembly and when you press in the clutch - if one plunger isn't seated, goofs up the systems ability to prepare the engine (Kicks up RPM) when you release the brakes and begin to release the clutch, this also affects how the Hill-Assist works in how long the brakes are applied as you begin to move from a stop on a hill (preventing rolling backwards)
It won't set a DTC because this is a SPECIFIC condition to the Body Control Module.- nothing wrong with the engine, but it affects drivability.
Winfield
2012 Fiesta
Handy andy
How did you fix this?
There are two switches on the Manual - one plunger works the Idle-up and Hill Assist "sets to ON" then you use the clutch for shifting and everyday gear selection. Turns Off when you release, or take your foot off of, the clutch
The other Switch "sets to ON" when you full depress the Clutch - it's Plunger goes all the way in and lets you START the car. It goes Off once you release the clutch - but if you hold the Clutch in all the way to the Floor - it will let the STARTER crank until the CAR starts or if it doesn't start - will let the STARTER turn until it does.
Read this thread to help with this...
https://www.fordfiesta.org/threads/...adio-for-2012-fiesta-s-sedan.10216/post-29463
The STARTER switch is all white and it's Plunger goes in...
The Idle Up Hill Assist plunger goes out to engage - and it's all black.
They reside under the dash- at the Clutch pedal on the Manual - or if you have the Automatic, you only have the ones on the Brake light - under the dash - behind the knee panel.
One switch, the Black one towards or closer to the dash panel (towards you when you're seated) uses a "flat" on the pedal (looks like tab) that lands on the plunger - the plunger is seated in a bracket that with 1/4 turn - pops out the plunger so you can replace it or tweak the flat so it strikes the plunger more squarely - which was the problem on mine. The plunger stem and the flat of the pedal-side - did not match up well so it needed the plunger to be removed, and re-seated in the holster to make the plunger fully extend and re-seat and won't "bind" and keep the pedal partially down to the floor as it gets stuck in that position and can lead to a problem with shifting using the clutch - so it may not full engage or disengage - making driving a mess until you get the plunger to retract fully back into itself and the clutch will start to work normally.
