Windscreen Washer Nozzles
Stockport
2018 Ford fiesta
My daughter has just brought round her 2018 Fiesta ST Line.
Wipers and water motor seem to be working fine but there is no water to the front or rear windscreen.
The nozzles on the front seem to have two wires to them running alongside the water pipe, are the nozzles heated or are the wires for another purpose?
Thanks for any help
L8gan
Glasgow
2018 Ford Fiesta ST-Line
Hi there,
I had the same issue with my own. Turned out that the fluid reservoir where the washer fluid would rest was clogged, I’m assuming it was from previous winter screenwash sitting too long or the likes, just had to remove the tank, and flush it completely and top back up and mine was good to go.
Unsure if this will help, good luck!
Thank you for stopping by to tell us this.
Many times we often forget to look at the simpler things because most of the time we have figured that the Poster had already tried them to no avail and exhausted other avenues to try - except we often forget the obvious.
