WHERE TO BUY PARTS
talisker
Hobart
Australia
Fiesta 2010 1.6 P Manual
Hi guys I am a new WS 1.6P Manual owner and wanting to know is there any one place that great to buy parts from local or overseas, many thanks I am planning a timing belt/tensioner/water pump asap.
I would strongly suggest that you get Ford original parts for your timing belt replacement. While you have it apart do the water pump and the timing belt tensioner along with the bolt that holds the tensioner. You do not want to go back through that process again! You also should replace the accessory drive belt too if it is more than a couple of months old it won’t be as stretchy as it should be. Good luck with the task in front of you!
T
talisker
Hobart
Australia
Thanks appreciate the advice.
