What led bulbs are you using?
darkgnite
Just bought a 2012 fiesta s and wanted to know if any of you have had luck with led blinkers? Set I tried gives me the rapid flash issue.
D
darkgnite
Thanks for the reply. Does it not have a led relay I can swap like I just read about on some cars?
Load resistors are super easy to install, one side connects to the blinker wire and the other to the ground wire.
Just make sure you mount the resistor in a place where nothing is touching it as they do get real HOT.
