Upgrading Passenger Seat on a 2013 Fusion SE to Power
pike1181
Hi guys,
Recently purchased a brand new 2013 Ford Fusion SE loaded to the max with every feature you can get from the factory.
The only problem is that the passenger seat is manual rather than a 6-way or even 10-way power seat.
Primary reason for wanting to swap the seat out is that it's too low. I thought about adding spacers to the base to raise it a little bit but not sure how that effects safety in an accident. Has anyone had any experience or have their two cents they would like to input on this scenario?
Has anyone had any experience with swapping out the seat for the titanium version (which is a 10-way power) or the 2012 or 2014 SE versions which are 6-way powered?
I'm guessing we would have to tap into the electrical wires to supply power to the seat as well?
Any input or advice would be appreciated.
Thank you!
