Turbo water Leak
Tambo
Glasgow
1.0 ford fiesta ecoboost
Hi, I have a 2013 fiesta ecoboost 1.0 with a water leak between the turbo and the engine block. Water pouring out. Would this be an easy fix or is it another new turbo?
If the turbocharger is removed and inspected it might be determined that it is Ok. A careful inspection is the only way to find out.
The cooling system on the 1.0 is rather vulnerable to failure in several different areas. Some items are easier and less expensive than others. The 1.0 Ecoboost requires an owner who is very diligent about preventive maintenance. One failed component is enough to destroy the engine and the maintenance budget.
