Sign Up! To view all forums and unlock additional cool features
Hi. New member here. I am installing a Curt trailer hitch and wiring harness this weekend. Curt wants us to run a feeder wire for power all the way from the battery. Can power be picked up any where in rear end area. Thanks!
Thank you. I was looking for power in the rear end to tap into. Found out today, there is none. Thought we could run it inside and tap the fuse box. No go there either. Had to run it under the car as described. Thanks for your help!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
