The REAL info on how to change transmission fluid on 2016 Edge Titanium 3.5L AWD needed
Huntsville
AL
2016 Edge Titanium AWD 3.5L
Hi, this may have been discussed before. But I have not found any youTube videos that have the correct information for changing the transmission fluid on
2016 Edge Titanium 3.5L AWD 6-speed. Mine DOES have the large fill hole on top of the transmission (under the air filter box) AND it DOES have a dipstick.
I was under it today on a lift and the only thing I can find that MIGHT be the drain plug and a level plug are very SMALL bolts. The heads are probably 8-10 MM.
They look to be in the right places, but all the videos show much larger drain plugs.
I understand that I have to change at least three times to get all of the old fluid cycled out (including the torque converter).
But any inputs here would be welcome for ones that match the details of my car.
THANKS
