Orange wrench light w/ car stalls, wont start and doesnt see what gear its in.
Palm Desert
2014 Ford Fiesta SE hatchback
Hi, I drive a 2014 Ford Fiesta SE Hatchback 1.6 l engine.
Orange wrench light and traction control light illuminated, vehicle shuts off and no longer shows what gear its in. Also when I turn the key off and try to start again it will NOT start, and again will not recognize what gear it is in.
My friend and I replaced the TCM in the vehicle a few months ago. And I used forscan to do the adaptive learn for tcm, it was sold out me as a pre-programmed ready to use TCM!
Only way I can get it to start is by removing the starter relay and bypassing it with a wire. At which point if the key is in the second position the vehicle will start, and show that it is in park, but this will happen again within not log. Please if you can help me or have any ideas please let me know.
Please and thank you!
You need to start with cleaning the ground connections on the underside of your Fiesta. There is a cluster of them near the lower transmission mount. There is also a few ground connections under the battery tray. That means that you have to remove the battery and the tray to get to that area. Almost all of the quirky behavior of various features and equipment can be caused by a weak connection to the ground. The smaller the voltage is, the more important that it has stable voltage. Too little voltage is not good. Too much voltage is not good either. CANbus vehicles require stable signal voltage.
When you start cleaning up the connections, make sure you tighten them snugly and then apply a good amount of petroleum jelly or what most people know as Vaseline to both sides of the ground connections points if you can get a finger under the ground point. Cover that bolt/screw and the eyelets where the wire is exposed and attached to the eyelets! You don’t want to be needing to go back to the ground connections in the near future.
