No start, no dash when hot.
Joliet
IL
2014 focus SE
Hi all, my 2014 Focus Se will not start on very hot days after driving for a while. Battery is good and alternator is charging. No check engine light or fault codes. Bad relay? Getting too hot? If anyone had a similar issue, any help would be appreciated.
London
Ford
Had the same issue, and it turned out to be a wiring issue—a short circuit in the TCM. However, you might also want to check if you're using the wrong loom first. Additionally, replace the starter relay if it gets too hot. Open the connector and clean it with electrical cleaner.also to adaptions for battery replacement. And reset bcm through diagnostic. Good luck
Sent from my iPhone using Tapatalk
