new/ old Fiesta owner
v8deuce
Lumby
2024 f150
Hi all hope everyone got through Christmas without having to remortgage their house! I'm new to the forum with a interesting problem I'm hoping someone might be able help me with, I'm pushing seventy and have been retired for a few years but still love to be in the shop tinkering. So my delema is that I bought a 2015 Fiesta with a 1 liter three cly from a auction that was a non runner, no problem there is not much I can't repair and as a licenced auto tech I was game so I took it on as a challange more than a investment. Fast forward a few months the engine was absolute junk, someone had run it out of oil and spun the rear main in the block with more damage than was repairable. Next I looked for a used engine with absolutly no luck except for one that the owner thought was made out of gold. After a few months a 2014 Fiesta came up on a different auction that had front end damage and was a salvage unit but was a 4 cly auto rather than my 3 cly stick so I bought it with the idea of swapping everything over, all went well with the swap and now to through a wrench into the mix we moved and it sat for a couple more months i'm back on it to try to get it up and running. I had swapped the complete wiring harness and engine trans as a unit. After checking all my work and making a few repairs to things I never got time for before the move I threw a battery in to check lights etc but for some reason I have nothing almost like the battery is not hooked up, I have got power at battery and following the positive to the fuse panel next to the battery I have power to it and some of the main fuses but nothing any farther, nothing under the dash or in the fuse panel behind the glove box. I am trying the find a wiring diagram that I can trace the wires to find where the problem is. I have gone over all the plugs, grounds etc with no progress, key does nothing no 4 way flashers etc anyone have a idea where to look? Thanks for letting me join I'm excited to learn more about my car and the people that own them. TIA Randy
Welcome aboard Randy! Have you tried replacing the entire fuse box in the engine compartment? It looks like a pain but if you're not getting any power to the in cabin fuse box it might be the culprit.
V
v8deuce
Lumby
2024 f150
awesome thanks I was thinking that would be my first area to look for the problem. I don't think our cars are any worse than any others and this car was subject to the weather as the hood was bent up from the accident.
V
v8deuce
Lumby
2024 f150
If you can believe it I found the problem turns out of none of the electrical connections plug into another one unless it's supposed to but Ford decided to make the two big plugs at drivers kick panel in the same place, the same and of course I had a 50% chance of getting them in the right order. Nope but after a few choise words at Ford for making them fit each other I switched them and was happy that everything started to work but still no start as in the motor don't turn over. I called a buddy that dropped over with his laptop and forscan, he changed something to do with the theft system and had it running in a few minutes. After a good test drive I have two issues left to fix one is the airbag light which scanner says is drivers seat belt and the hvac thinks its 150 degrees so the a/c is trying to lower the cabin temp even though the temp control knob is on hot. On a positive note this car is awesome to drive and super on gas! If anyone knows how to repair air bag light and temp I would greatly appresiate any suggestion's. I did find a guy on you tube that replaced the left front impact sensor and that got rid of the light, I haven't tryed that yet but I've changed the drivers retracting seat belt that has the sensor on it but that didn't help.
Randy
