New member 2016 Fusion Titanium lighting issue
Texasgary
I have noticed that my Fusion has no lighting to the side of the front headlights. The light bulb is surrounded by a can shroud that keeps any lighting from going to the side to help in turning corners. I have an F150 that provides enough lighting to light the turns at least enough to see the edge of the road. Is there a separate sidelight that I cannot find or may be burned out. I purchased this as a Certified Preowned with 23k on it so I have no idea if it should have lighting or not. If not, I would consider that a design flaw.
FusionMike
There's no side lights on the 2016 Fusion headlights. On the 2017 they come with dynamics LED lights that will swivel around corners.
T
Texasgary
Thanks for the reply to my query. I was afraid that was the case. Very poor design. I personally would consider it a safety issue. Disconcerting to turn where you can't see what you are turning onto.
