How-To: Fiesta ST Rear Tail Light Bulb Replacement
Items Needed:
1) Torx T25 (Star Style) Screwdriver
2) Rear Bulbs: 3157, 3157A, (906, 912, 921, W16W, W15W, W5WB)
Step 1 - Use the small torx screw driver remove the upper screw.
Step 2 - Use the small torx screw driver remove the lower screw.
Step 3 - Gently pull the rear tail lamp housing from the mounting sockets.
Step 4 - Untwist the bulbs from the housing.
Step 5 - Bulbs.
