Fiesta Front bumper compatibility
Winter Park
2011 Ford Fiesta SE
Does anyone know if a 2014-2019 fiesta front bumper would fit on a 2011 fiesta?
It's not a simple direct swap. The hood panels are different between 2011-13 and 2014 up.
The headlamp capsules are also changed for 2014 up.
I am seeing prices of over 600 bucks for a complete 11-13 front bumper cover assembly. That's for a cover with grille and bezels along with the lower apron pieces. That doesn't include the splash aprons inside the fenders (i don't know if they are same as earlier ones) and the headlamp capsules are around 150 bucks each used.
So, none of this is inexpensive. I have both versions. I don't see any advantage with the newer headlamps. Its just gingerbread. Expensive gingerbread.
Dracoblue777
Winter Park
2011 Ford Fiesta SE
Nothing is simple with this car of mine, but I saw the 2015 bumper and headlights for cheaper, but I wasn’t sure if it would all fit, since I don’t have anything to compare it to where I’m at.
Yes. Parts are SO expensive that i have decided to "borrow" the bumper cover assembly, headlamps and the crash sensors off my 2011 blue hatchback just to confirm that the headlights and airbag systems are fully functional. Before I drop the money on the cover.
I know that it could cost at least $500 to replace airbag monitors and a harness plus a couple of crash sensors.
I can start and drive my project hatchback around my shop. But every warning light in the cluster is glowing.
I sometimes have days like that, just trying to get out of bed...
It's those winking lights in the upper corner of your eye - sort of thng...
STL
2019 Ford Fiesta SE
A soldering iron should be able to take care of those pesky lights...
Dracoblue777
Winter Park
2011 Ford Fiesta SE
I might just have to buy a bumper and headlights to test it out. But that’s a project for sometime next year.
