Anybody else getting "Battery Saver System Off" reads?
jmgregware
2014 hybrid - 63,000 miles. All of a sudden, I'm getting this on the center display panel: "Battery Saver System Off" with a 'loading' bar showing when the car is shut off... Appears to be a problem with the battery from what I have found regarding this on other ford cars... Any idea's?
JClintB
Lyburn
WV
2019 Fusion SE Hybrid
Sounds like the Battery Management System needs reset. Turn the key on but don't start the engine, the battery indicator light will be on, flash the hight beam lights 5 times by pulling the signal light lever back, then hit the brakes and release 3 times, then watch for the battery indicator light to flash three times, takes about 10 seconds. That will reset the BMS, battery management system. This works on most all Fords from around 13 up. I know this is an old thread, but figured others may see this and can use it.
