2009 wheel swap
bratboy
hi folks, are all the wheels from the first and second generation cars swappable? I know they are 4x108, I'm just wondering if the offsets are all the same. thanks!
ajrn
Toledo
OH
2009 Focus SE (gf's car)
I picked up some steel 15" 4x108 rims that the previous owner had used on an '09 to bear snow tires.
You have to remember the hub size "hole" may vary as well. I got bit on this once, trying to put Saturn rims on a VW. The offset was similar, the pattern was the same. BUT my V'dub had huge hubs (diesel) and they wouldn't have fit without some sort of adaptation. Since VW's and almost everything use LUG BOLTS, instead of lug NUTS, I passed..
Good luck, I hope that helps. :/
